Minor Issues?
Omasis`
1. Started my car up this morning and right after the starter motor had engaged and had cranked the engine, it made a funny metalic scraping sound almost like it didnt disengage for about a second. does anyone know where the starter motor is located obviously its somewhere round the flywheel but is it easy to access? .
2. I have a rather annoying squeek sound which i believe is coming from the exhaust / heatshield it happens everytime the engine moves ie pulling off changing gear etc. does anyone know where i can get replacment heatshields? or any advice on how to fix this issue?
For those of you who dont know my car is a CTS 54 plate with 56,000 on the clock.
Thank you for you time :thumbsup:
Sounds like the starter clutch pinion gear is sticking ( gummed up with clutch dust probably ) and is located under the right hand side of the
Inlet manifold - just remember to disconnect the Neg - Battery terminal before removing the starter motor.
As for the squeek , it could be anything tbh :
* Exhaust manifold heat shields corroded/rattling.
* Exhaust manifold to downpipe bolts or the tension springs on the bolts.
* Drive belt Tensioner
* Clutch Release Arm pivot dry and squeeking ( can be heard with engine off and clutch being operated ).
Process of elimination will find the Squeek.
Mick
Thanks for that. I can stop dreaming about huge bills. I have exactly the same noise when starting. But only about once a week. As its an automatic it must be in need of some oil and a belt with a hammer!
Thanks, will be taking a look at this on the weekend me thinks providing the weather is nice. at the minute it only seems to do it when cold.
