Wind Deflectors
nigel129
Can anybody tell me what to use to replace what ever padding sat beetween the wind deflectors on my front windows. Ive tightened the clips as tight as theyll go and the vibration is driving me NUTS :eek: :ffs: . From what little is left, it looks as if it was a thin strip of foam, possibly sticky. Is there a DIY job available or can the strip be purchased somewhere,
Hi bud, you could try thin draught excluder, the sticky backed type. :rolleyes:
thought of that but only seen it in white and seems a bit thick for the space between the plastic and door rim. thanks
