01 Toyota Avensis D4d
ncc98071
Hi
I have a 01 toyota avensis d4d , that was sluggish to start last night and this morning, Then I tried it again there now and it wont start at all, the lights on dash come on , but all I hear is a clicking noise, tried jumpl leads and the same thing.
Any ideas what it could be, starter I was thinking
Also would a tow get it started so I can drive it to garage
Also any ideas what the cost of a starter would be
Cheers
Sounds like the Battery or a dogy connection. But if you say you put jump leads on and it still clicks, then I would check all your connections from the Battery to the earth on the body, and from the Battery to the starter motor. I don't think that it is anything more than that.
Yes the car should start with a push.
Hi
Cheers
hi mate
yes clicking noise is only clicking but the grease lack does not allow solenoid stem to switch ON the starter power contacts.
So have solenoid serviced first + charge Battery and try again.
Cheers/Igor
