Ts Springs
andycam06
Think only facelift TS is 15mm lower..prefacelift is same height as normal rolla. I'm sure someone will clarify ;)
Correct ..... ;)
cheers lads, brother in law has a t3 but loves the cts wheels, he got a set of 16" str's and was planning on droping it 40mm but now a set of cts alloys are after popping up and springs, so ill have to find out if they came off a pfl or fl, cheers
