Tsport Alarm Always Going Off.....
ljcni99
As the title says... my alarm keeps randomly going off. At first it wasnt too bad but now its started to go off at night and i fear my dad might kill me if it goes on much longer....
Any1 else had this problem? If so how do i fix it??
i think there is a sensor under the bonnet that gets bent down a little bit. sure i read somewhere on here that you can bend it back up again and that solves the problem.
Quite often the bonnet pin switch or the actual bonnet hinges (especially the near side hinge) tend to sieze and the bonnet does not close properly,leading to
a false alarm trigger from the bonnet switch.
Mick
