My Corolla Gti Wont Start Please Help
toyota-rolla
i have a toyota corolla 1.6 gti
on a f reg 1989
it wont start
i have checked all the fuses under the hood and inside on the driver side.inc the efi relay under the bonnet
engine turns offer ok bit it wont just fire up..
there is a spark from the coil lead
the timing belt is ok not slipped or any thing like
can any one suggest wht could be wrong or what i can check
your help would be most apprecaited
on a f reg 1989
it wont start
hi mate
if sparks are available -- what about petrol?? Check with booster pump or its fuse.
Cheers/Igor
hi i have checked the fuel
u can smell it in the exhaust system when u turning it over
also if u keep turning it over eventually the plugs get soaked with fuel
just wont fire up
hi mate
Cheers/Igor
Maybe the distributor cap is faulty? Check the connector ends by taking off the red cap. I know you say there is power but it might be on and off.
And are the leads properly plugged onto the plugs, with no bent connections or corrosion etc.
the leads are all plugged in correctly
i have checked the plugs
i also have changed the distrubutor cap
and checked the efi relay under the bonnet on the passenger inner wing
on a f reg 1989
it wont start
If your sure your getting fuel and a spark at the plug how about taking the plugs out and drying them on your gas hob, pop them back in and it might start, the cylinders might be flooded with fuel if you've been trying all day to start it.
Has it been sitting for a while? Your fuel in the tank may have "gone off" or decomposed which does happen if left for a while.
I dont know a great deal about your particular engine but, if you are adamant you have fuel getting through and a decent spark:
Are the valves opening ?
Have you checked compression ?
yes compression is ok
Compression + Air + Fuel + Spark = Combustion ??
So you have had checked or checked yourself the compression of each cylinder?
How was it checked ?
Check your ECU mate see if you can borrow one or buy a second hand one and see if that works :thumbsup:
if you have a spark (and it is a good one) and fuel it has to be timing related, either the plug lead firing order is wrong or there is somthing more serious wrong
all sorted
thanks for your help
timing was ok but the rotar arm was at number 4 position
when it was suppose to be at number one when timing marks aligned up
distrubutor removed and refitted
started 1st turn of the key
good one. easy mistake to make. ive done it before :blush:
