Rear Wiper Stays On Constantly
wuly1554
driving it today and noticed the rear wiper on so switched it off
5 minutes later come back on permanantly and now i cant switch it off
could this have something to do with my electric wing mirror
being smashed off a couple of days ago,(electrical short of somekind)
I doubt it.
I had this problem late November. It was the stalk that was the problem (It appeared!!). I solved it by twisting the rear wiper control slightly farther than it usually goes Then back again hard. After about 30 times of doing this, it came ok & has not caused me any problems since. I also used a safety solvent (Gun foam cleaner) on the stalk as well, but don't know if that helped & or solved it. I think it was either moisture or dust in the mechanism.
Marv
Most wiper motors are earthed switched so if there is an earth leak either at the connections or inside the motor then it will continue to run. Sometimes the self-parking mechanism inside gets gummed up and if you can get access inside the a clean up an some fresh grease cures the problem.:)
sort now folks, cheers for the advice was a big help
took the rear motor out was quite wet,sprayed it with wd40 and left it on a window ledge above a radiator
for the night,put it back on today and works perfect
Good result..
Trick is to seal the top rubber bung..
water wont get down their again
