Spacers And Stock 16'' Rims.....
ricc
Ok, can't believe I'm actually asking about spacers lol, but here we are. In the past on previous wagons I've been able to swap hubs out for a different model which has given me a wider track whilst retaining std fitment of all other associated drive-train parts. However, I know not of a solution on the corolla.
What's the most you can push the std 16'' rims out before you start having issues with needing longer studs and the eventual bearing issues.
Clearly new rims on a different offset would sort all this out but I'm not looking for a wheel swap. If there's no safe compromise the wheels shal remain hidden under the arches as is.
ive been thinking the same thing...
those standard rims look hidden under the car...i dont actually know if any1 sells spacers foer the t-sport?
I believe people have run 5mm spacers in the past with no problems...
