Corolla T-sport Engine Code S0135
cibies
Hi everyone,
I have a pre facelift corolla T-sport with 130k miles on it. I have had it nearly 2 years now and have had next to no trouble with it until now. The engine management light has come on switching off the TRC and VSC. I have tried disconnecting the Battery to reset the ECU but it comes back on again. I bought an engine diagnostic kit on eBay and connected it to the cars diagnostic plug the other night. It gave me the following error code
Corolla T-Sport Engine Code S0135 H025 Heater Performance Bank 1 Senso
I was able to clear the code and switch off the engine management, TRC & VSC lights. So I thought that it was just maybe a glitch or something. The following day I embarked on a journey of over 100miles and about a half hour into the journey low and behold the light came on again. Does anyone know what this code means and where is this sensor?
Hi everyone,
I have a pre facelift corolla T-sport with 130k miles on it. I have had it nearly 2 years now and have had next to no trouble with it until now. The engine management light has come on switching off the TRC and VSC. I have tried disconnecting the battery to reset the ECU but it comes back on again. I bought an engine diagnostic kit on ebay and connected it to the cars diagnostic plug the other night. It gave me the following error code
sounds like you have got a faulty oxygen sensor.
they are found on the exhaust manifold usually have 2 sensors before the cat then 2 after. bank 1 sensor 1 is for cylinders 3 an 4. bank 2 sensor 1 is for
cylinders 1 and 2. bank 1 sensor 2 an bank 2 sensor 2 are fitted after the cats.
Cheers man, I have spoken to my local Toyota Dealer and they have asked me if it is the front sensor or the back. I take it they mean either the manifold or the cat? Surely the 2 on the manifold wouldn't be different? I know I can get get an aftermarket one probably cheaper. Toyota are looking £140 + VAT does that sound about right? Any ideas of a part no.?
cant help but what kind of diagnostics did u get was it like an OBD2 reader or something?
Ok I had a look at the Corolla at the weekend and I can only find 2 oxygen sensors. One at the engine side of the CAT and one the other end of the CAT. Am I right in assuming that Bank 1 sensor 1 would be the one at the engine side?
Hi everyone,
