Mr 2 Mk2 Wheel Spacers
Roytoner
Doe's anyone know where on this planet I can get a set of W/Spacers about 25 mm wide been trying for ages to find some HELPPPP :crybaby:
Bibbs have you fitted longer w/studs to fit you 8mm's ??
25mm ?? That's quite a bit .. why do you need ones that wide?
I've got cheap Halfords 8mm ones, but they dont locate on the spigot ring like good ones should.
I saw a set in Holland, a they set the rear wheels out just right, also got ripped of with my wheels both front & rear are 7 J it's a long story but I can't send them back :crybaby:
