Whats This Connector For ?
meltonlad
ive removed my standard stereo to fit my bluetooth kit and i noticed a spare connector with a grey foam thing round it. all the connections on the back of the stereo are taken so im confused now !!!
Got a pic of it?
i !Removed! knew someone would ask that after i have put it all back together !!!!!! LOL no i aint sorry but it was about 2" long and i would say about 14 pins maybe more !
Did you spot it BEFORE you took it apart, or was it when you put it all back in, a spare connection block became apperent.
Seems very odd, you sure you haven't forgot to connect it back into the H/U or maybe from the centre console or something.
i did look but cant find anywhere that it should go. i think its been part of the loom as if i remember right it was coming off the stereo loom bit i think ?? maybe it could be for sat-nav stereo ????
I take it you connected your bluetooth kit in the back of the H/U then?
Could explain why you have a spare connector block, but what have you lost from doing this then?
i fitted my parrot kit but had to get a SOT-062 first. im 99% sure that the connector was spare when i removed the stereo as i has a good look at everything before disconnecting anything... everything is as it should be after fitting it..
If you still have the original H/U, there are 4 connection ports at the back of it, a bit like this.
Now i know 3 of them are for the speaker outputs and power for it, and i've one spare too from the trip computer which i've got spare too.
Will try and get a pic of it, and see if it like the same as the one you have spare too.
