Surf Front Cv Joint Removal?
aidantrafford
Hiya! Newbie here. Does anyone know how to remove the front driveshaft cv joint from the hub assembly? Does it just pop out if you belt it, or do I need a bit more finesse?
Thanks in anticipation!
Are you asking this for your surf?
If so perhaps the hilux/surf forum would be better
Sorry crofter, I though I was on the Surf forum!!!{mental note to myself"must read things before pressing buttons!"}
