Power Loss
Ricki01
I have just changed a faulty gearbox on my Avensis, I had the Battery disconnected for about 4 hours, I have reconnected all plugs and leads that I disconnected in order to carry out the job.
The problem I now have is that the car seems to be missing badly, and as in missing I mean it feels like the timing is out, there is no power when I press the accelerator off and on, if I press and hold the acccelerator down it revs up quite slowly to max revs.
Has anyone also had this problem, if so can you tell me how to remedy it, is it just that the ECU needs resetting? if so is there a non dealer way of doing it?
Thank you in advance for any advice.
Richard
I really need some help with this as I am car-less until it's fixed, anyone any ideas at all?
