Rear Shock Absorbers
Chopsy
Hi all.
I sent my old mans car for an MOT it finally failed for the first time :o on the OSR shock.
I've been advised to replace both. Anyone recommend a good replacement set? I've had a little
trouble finding them so far as it the Japan version from 1993 with the JT chasis.
Thanks.
Try to get into contact with Parts King I am sure that he will be able to sort you out. ;)
Kayaba Excel-G 333108 its posible to use it more than 150000km even on bad Russian roads.
or Tokico
