Tsc Engine Oil?
THB_COMPRESSOR
Silkolene PRO S 5W-30
Name has now changed to fuchs titan pro S
Top Stuff, I may change over to Motul 300V later if i see more track time.
I've got a 2.0 D4D and I use Toyota's own 5w30 oil. Never had any troubles with it although I'll probably change to thicker 5w40 when the engine has some more miles on to help prevent knocking and make sure whole engine gets oil.
