Defective Horn!
alan589
The horn on my 2006 has stopped working. Was a bit intermittent then gave up the ghost. Can anyone shed light on the most likely cause? Also, can I just pull the steering wheel boss cover off? I get a bit nervous with all that new fangled air-baggery about.
Ta
I have just sorted youngest son's 2001 horn.
If the same, the connector to the horn - mounted just below the horn - corrodes slowly over the years and eventually stops passing current.
Disconnect and clean with emery paper. (or very fine wetand dry sandpaper)
I would agree with the outside part being the likely culprit... I would,nt try mucking about with the airbag system until testing the actual horn itself! :crybaby:
