Electric Windows
jim1933
Me and my Carina again! is it very difficult to get at the drivers window on my 1996 Carina to lubricate the runners, any help much appreciated :help: Cheers Jim :thumbsup:
Get a can of wd40 with the little straw attachment. Remove the door card, you should then be able to point the straw in the direction of the window runners.
hope that helps.
:thumbsup:
buy a can of lithium grease for a proper lubricant.. get this from Halfords... spray on thin and sets into a grease. WD40 is bad for electronics
  • 4 weeks later...
:bookworm: :hokus-pokus: :D ;)
hey jim
try wourth rubber care formulation
surely it works fast & easywith no other effects like swelling the runner rubber as experienced by use of wd40/oil base lubricants/rust removers(a strict no no )
take care
Thanks to you all for the help, it looks like I need a new window motor drive as the window comes up very slowly and a couple of times I have had to pull on the window to help it up, any one know how much this little job is gonna cost :D
