93 Camry
carlosalfaro
I have a 93 camry and my mechanic has been putting 10w40 oil in it for a while now
the car has 150K miles on it.
Anyone has any suggestion of maintaning that oild? going to 10w30 or other weight
or even going with a syntetic blend or all syntetic for the car?
any input will be greatly appreciated.
I just bought a 97 Camry from a local dealer. The pervoius owner had it serviced at the dealship. They use 10-30 there.
I personally perfer 5-30 and will change to that the first oil change I do. If the temp. where you live gets real cold, then the 5-30 might be a better idea. Else 10-30 is what Toyota uses.
Thank you. I think I will do 10w30 summer and 5w30 in winter
That seems to be the most reasonable thing to do
thanks for the input
