Grinding Noises In Neutral
lynseywilson
Hi. Very recently (the last day or two), I've noticed my engine making a sort of grinding noise when my car's in neutral. As soon as I hit the accelerator the grinding stops, but as the revs slow it comes back quite loudly. Has anyone else had this, or know what it could be?
Have you checked you oil level, what happens if you push down the clutch pedal ?
It sounds like it might not be disengaging properly, or rubbing slightly, this could be anything, so if it isn't oil levels etc... take it to a mechanic or dealer asap. If your car is under warranty? this should be fixed for you for free.
Never heard of this problem in an aygo before however.
