More Lexus Malarky!
SuperRetard
!Removed! lights! Got my second set through from VSUK, fitted'em this morning... before work... then found that the wiring was wrong and that the driver's side plug still wouldn't twist and locate! Re-wired the buggers (only two wires mixed up it turns out) and literally hacked the oe Toyota bulbholder until it fitted in. No doubt it'll rattle like a ***** when I put the oe lamps back in, but nowt a little chemical metal won't fix...
Beware the cheap stuff! :blink:
not havin much luck are ya dude!
cant believe how mine fitted so easily???
I had the same trouble with 1 bulbholder SuperRetard but i just forced it in the same as u!!! Mine fitted really easily 2 tho!!!
:D
so you dont know if it said vitz on the side of the box in small writing
