Sera Suspension Upgrade
theoldfonz
Is there a way of improving the ride on my Sera?
I have been told coilovers would help.
Has anyone done this?
many thanks,
I also need to locate the fuel pump on my sera as I think it might be on its way out.
Does anyone know where it is situated and how easy is it to remove?
regards
The fuel pump is located inside the fuel tank - directly under the Central armrest thingy on the back seats. If you remove the back seats ( couple of screws from memory ) and the armrest you'll see a plate on the tank - remove this and the pump comes out with it.
Thanks,
I will tackle this job next weekend,
Regards
Hi, I changed the fuel pump yesterday (for a more powerful unit) and then the car would not start.
I think it is now getting too much fuel.
So I adjusted the fuel regulator but it now it stalls when it gets hot and will not re-start unti lit is completely cool again.
Does anyone know what I should do.
HELP!!!
