Sign in to follow this
TAF
100A Alt Fuse
Fuse is located in the engine bay, just wondering how to take it out? ive been told its screwed in but cant see how
Share this post
Link to post
It is screwed in, you need to dismantle fuse box by unclipping and unbolting it. Once done you will see the fuse is bolted in to two ground wires. You need to unbolt the really small socket caps.
You can then remove the fuse and replace. The type you need is a slow blow pal fuse with straight legs.
Share this post
Link to post
