Yaris Speakers
corollawew
i have a YTS which i've just bought four 10cm Speakers to replace the rubbish ones already fitted. are they the right size????
If so, how do you get to them to change them???
(i have fitted my own headunit by the way!)
those Speakers should go directly into the dash(10cm 4inch), Ive got (5.25inch 13cm) in the door, by using a spacer on top of the original spacer, pic will be online soon
you can pop the dashboard speaker grill off by prising them off from the rear facing end with a small knife
its also i right git to unscrew the original speaker off the dash cos of the windscreen bein in the way
use a ratchet and screwdriver bit
