Sign in to follow this
GlenPF
95 Corolla Gxi Speedo Not Working
As above, the speedo & mileometer is not working on my 95 Gxi, from the previous owner " its not worked for approx 12 months now". Is this mechanical or electrical (before I start removing the dashboard)? :thumbsup:
From what I have searched, i'm looking at a speed sensor change?
What should i be looking for? :huh: What does it look like & where is it?
Any Help would be apppreciated.
Glen.
Share this post
Link to post
Glen.
Is the speed sensor on the gearbox? :huh:
Share this post
Link to post
Yes the speed sensor will be on the gearbox. If it is a cable then you may have a kink/snap in the cable, but if it is electrical with a sensor then you will have to replace the sensor. Either way what you are looking for is on the gearbox. :thumbsup:
Share this post
Link to post
Thanks for that. :thumbsup: I think I know what i'm looking for... :huh: :)
Share this post
Link to post
No problem mate, it's what I'm here for. That and for membership discounts. :lol:
I hope you find it without too much trouble. You may just find a snapped wire or whatever so just keep an eye out for any abnormalities. :)
Share this post
Link to post
Found the culprit, just need to check power supply etc.
Share this post
Link to post
looks like its the sensor itself, power is going to & from the sensor to the clocks but its not sending a signal, if that make sense. Going scrapyard hunting.... :thumbsup:
Share this post
Link to post
No luck at the local yards, time for ebay & the net! :thumbsup:
Share this post
Link to post
How can I tell if a speed sensor, working or not? Is there a way of testing/checking it other than plug & play? :unsure:
Share this post
Link to post
You'd have to test the resistance, however I don't know what reading you should get from the ohmmeter
Share this post
Link to post
should be able to check that :thumbsup:
Share this post
Link to post
Its all good, until the guy says he's snapped it taking it out. Have to find another now, worried about taking the old one out to! :crybaby:
Share this post
Link to post
wow what a nobber! :censor: Sorry to hear that, I'd have gone ballistic!!
Has he got another that you can have?
Share this post
Link to post
no, just a refund. The hunt continues. :rolleyes:
Share this post
Link to post
I would be very aware of the fact that is from USA, and they had different cars at the time so I doubt it would fit their spec.... :no:
Share this post
Link to post
I did think that, although it does say the right model, engine but not g-box. Will try & find the toyota part number I need 1st I think. :yes:
Share this post
Link to post
Found a breaker who has a couple, just hope it fits & works!
part number 83181-12020 for future ref. :thumbsup:
Share this post
Link to post
£18 less in the pocket but fitted & working!!! Big thanks to Toyota Breakers Ltd in Bury, Manchester.
Share this post
Link to post
