95 Corolla Gxi Speedo Not Working
GlenPF
As above, the speedo & mileometer is not working on my 95 Gxi, from the previous owner " its not worked for approx 12 months now". Is this mechanical or electrical (before I start removing the dashboard)? :thumbsup:
From what I have searched, i'm looking at a speed sensor change?
What should i be looking for? :huh: What does it look like & where is it?
Any Help would be apppreciated.
Glen.
Glen.
Is the speed sensor on the gearbox? :huh:
Yes the speed sensor will be on the gearbox. If it is a cable then you may have a kink/snap in the cable, but if it is electrical with a sensor then you will have to replace the sensor. Either way what you are looking for is on the gearbox. :thumbsup:
Thanks for that. :thumbsup: I think I know what i'm looking for... :huh: :)
No problem mate, it's what I'm here for. That and for membership discounts. :lol:
I hope you find it without too much trouble. You may just find a snapped wire or whatever so just keep an eye out for any abnormalities. :)
Found the culprit, just need to check power supply etc.
looks like its the sensor itself, power is going to & from the sensor to the clocks but its not sending a signal, if that make sense. Going scrapyard hunting.... :thumbsup:
How can I tell if a speed sensor, working or not? Is there a way of testing/checking it other than plug & play? :unsure:
You'd have to test the resistance, however I don't know what reading you should get from the ohmmeter
Ok then you are in business once you get the figures that you need to see. :D
Its all good, until the guy says he's snapped it taking it out. Have to find another now, worried about taking the old one out to! :crybaby:
wow what a nobber! :censor: Sorry to hear that, I'd have gone ballistic!!
Has he got another that you can have?
no, just a refund. The hunt continues. :rolleyes:
I would be very aware of the fact that is from USA, and they had different cars at the time so I doubt it would fit their spec.... :no:
I did think that, although it does say the right model, engine but not g-box. Will try & find the toyota part number I need 1st I think. :yes:
Found a breaker who has a couple, just hope it fits & works!
part number 83181-12020 for future ref. :thumbsup:
£18 less in the pocket but fitted & working!!! Big thanks to Toyota Breakers Ltd in Bury, Manchester.
