Sign in to follow this
SAM LOVERS HER TOYOTAS
Is It True Guys...
Just going through various threads on this site...found some saying the 1.6 04/05/06 corollas also have an Oil burning issue like the avensis vvti engines...is this true??? This could make me change my mind about buying my 1.6 Sr corolla tomorrow now! Please help asap. Thanks...Sammy
Share this post
Link to post
Yes this is true however it is not a fatal issue with the engine and it doesn't impair performance.
The problem is that the pistons rings are ever so slightly undersized so a little bit too much Oil is let into the cylinder and gets burnt off. This just means that you have to pay a little extra for Oil but it doesn't affect anything else.
Don't be so hasty to give up on the SR. ;)
Share this post
Link to post
Wasn't the Oil burning issue on the 1.8 engines found in the Celica & Avensis??? blink.gif
Toyota extended (un-officially) the warranty on those engines....
Not sure it's the same issue on the 1.6....
Share this post
Link to post
Wasn't the oil burning issue on the 1.8 engines found in the Celica & Avensis??? blink.gif
The 1.6 has always suffered from it, one of the first things I learned when I joined here. :yes:
Share this post
Link to post
sure was a problem wit 1.8 and 1.6 lol mainly avensis 1.8! not many corolla and celica we used to do atleast one a week but if the car is less the 5 years old an less then 100k wit full sevice history toyota will cover it !
Share this post
Link to post
THANK YOU guys for all your responses...they have kinda helped me make up my mind...conclusion...they do burn a LITTLE Oil but its absolutely nothing to worry about...so long as you keep an eye on it!
Sammy
Share this post
Link to post
Good decision! :yes:
I can't see it as a problem as you should constantly check your Oil anyway. :D
Good luck with finding one.
Share this post
Link to post
