06 Yaris Creaking Suspension
techy
Hi Guy's i have an 06 1.3 Yaris T Spirit, which has started creaking when going over speed humps or slowly over uneven surfaces, any of you guys out there got any suggestions ?
It does sound as if it is coming from the front of the car.
Thanks in advance for any advice
Techy :help:
Anti roll bar bushes are a common problem on the mark 1 Yaris, not heard about it on the mark 2 but worth a look. Will probably be suspension related - check all rubber bushes.
Spray the bushes with WD40 a good soaking. This will get into the Bush and Lub them.
It will come back, then replace the bush or bushes.
R
