07' Instrument Cluster
tatteam
I need help, for I need to replace my Rav 07' Instrument Cluster and would like to know what does it involve.
Thanks,
James
Dead easy. Drop the steering column and extend it out. In the attached instructions it says use a screwdriver but I just grip the bezel and pull it off. Undo the 2 screws under the top of the meter and then the pull the clips from the bottom holding the instruments in. It unplugs at the back. Not more than 10 minutes to change it.
speedo.pdf
And if yer disabled like masel, then a soft mat and knee pads....
Thanks friend, that's of great help. :thumbsup:
