Tappet Noise On Warm Engine Need Ideas 03 Hilux
Thanny
Hey all, my 03 turbo deisel hilux has a problem and need some ideas
i have a ongoning tappet noise coming from the engine. Was taking off went from first to second and the problem arised. A large grinding big ends noise (just went) started coming from then engine baY. i thought some thing was wraped around the tailshaft hiting the bottom of the cab but it was not to be. we have played around and tested most sensors relating to the thought problem with the multi meter but they all check out. it did sound like the big ends but now sounds tappets. its not blowing smoke. and only starts making the noise when the engine is hot. on start up it sound normal. as it is turned off the noise is a ticking over noise (if that makes sense) the injectors have been checked and are fine. they are tourqed up to specs. the belts are all new as we changed them coz we had the radiator out and cleaned it. the timing belt is fine and has not sliped a tooth. i have heard of a cracked exhaust manifold which we havnet check yet which will do tomorow but dont hold to much hope. Have run out of ideas and thinking it is fuel related. wondering if anyone has ran into this problem or has any ideas. and thoughts would be much apreciated as dont wanna take it in. yet.
thanks for any feedback
  • 3 months later...
Hi, I know this thread is old but I've got a hiace with extremely similar sounding symptoms. The noise sounds like a loose tappet or a duff injector and is only really pronounced when the engine is warm. Driving on light throttle is when it's at its worst.
Did you find the cause? I'm keen to know!
cheers
Ben Lord
I have exactly the same noise on my 02 D4D. It does my head in and have to keep changing my speed/throttle to stop it. Please help me to keep my sanity! Anyone??
the forum i usually frequent has had this problem come up several times,
the usual answer is, the d4d engine seems to have incredibly noisy injectors, if your motor is new enough you can take it back to the dealers
some people have had luck using comma diesel magic
i have tried it in mine and it did make a difference, defiantly going to try another bottle
  • 4 weeks later...
i pour about 300ml of 2 stroke oil in the tank every time i fill her up :yes:
