Seat Swap
notlob
hi,does anyone know if the seats and door cards from a 1995 5 door will fit in a 1999 5 door.
is there a more comfortable seat available for the rear. many thanks
I'd guess that they will. Check that the switches on the door are the same in case theres some cosmetic change.
The other thing is to check the seat belt mounting buckle is the same /same size for the belt.
On the seats, you can put a range of seats in, but you do need to modify the seat mounting - for example I have Cobra Monacos fitted in the front of one of my 1994 RAVs. Trouble I found with the front seats particularly was that the foam supports disintegrated. I have 2 rear seats from the car which I removed - butthe car is quite narrow so you ned to check what could fit in.
If you look to modify the seats mounting, then the petrol tank underneath may need to come out to allow access for mounting plates.
hi,thanks for your reply,i have found a set of standard seats in top condition and they seem firmer than mine.
i think mine have just gone soft with use.
the previous owner was somewhat of a large lady so was her hubby.
they may have squashed the foam. many thanks
