Check Engine Light
alniz
The check engine light moniters the sensorsin the engine.You are probably noticing lower fuel economy and perhaps poor performance.
This can be checked with a scanner-usually for free at Auto-Zone to see which one it is.
Even if the light goes out the code is still held in the computer.
  • 4 weeks later...
That is funny you say this because I have a 2000 corrolla with 57000 miles on it and the check engine light is on. I have had it check about 5 times over the past month and they do not seem to know what the problem is. very frustrating. let me know if you find anything out.
I have no idea how old this post is I was just doing a google search for information on what coudl be the problem and your post came up.
Kim
Hi- I don't know if this is the same problem but this use to happen to my Volvo a lot, when I looked into it I found out that all new cars (1998 onward, Toyo included) have a special gas cap mechanism to prevent vapor leakage; if you top the tank off when filling up it creates some weird dynamic on the fuel sensors (similar to what the other post indicated) so, to stop this from happening, I stop the gas pump when it shuts off by itself, or if I'm at a full service gas station I tell the attendant NOT to top it off (they like doing this to avoid odd numbered dollar amounts); ever since I started this the light has not come on once, good luck.
our camry engine light comes on when you turn on the cruise control sometimes.
its a throttle position sensor, ive just not replaced it yet.
