Little Problems
madmoody1
I,m having a few litttle problems with my rav.
1) when the rav has been run for a while it feels a bit sluggish like its holding back when accelerating.
I,ve just fitted a cone filter and some Iridium plugs as i thought that would cure it but its still there.
When it first starts it runs fine.
2)the alarm fob works fine to arm but its a real problem to disarm.
Then the alarm goes off when i use the key. :crybaby:
Everything is fine using the key but i would like the fob to work as its a bit easier.
Any help would be appreciated
I,ve just fitted a cone filter and some iridium plugs as i thought that would cure it but its still there.
does the alarm fob need a new Battery?
On the sluggish bit, I seem to remember ancs saying something about something causing sluggishness on something else :wacko: :wacko: :wacko: :wacko:
Try cleaning the MAF as well and maybe the plug leads could do with being replaced - 11 years old.
