Power Window And Door Lock Problem
shmrk
i installed new Speakers and disable orginal tweaters.after than only driver side switch is working (but without auto function) on driver side control panel. other 3 window switches and door lock switch not working. passenger windows working well on their door.
i tried to reset power windows by pull and hold button for a while but it didnt work.
and all windows work now with no key in ignition. swiftch blink 4 times when i push them.
i checked all fuses and wiring.
pls help.
sounds like you may have messed up a bit of wiring behind the drivers door when installing speaker. go over everything you touched and ensure every connector is secure.
