Aftermarket Clutch
alasdair09
I brought a new clutch got it fitted aftermarket one from fensport, the clutch plate release bearing etc, now im wondering if you have to set the pressure plate up adjust it or is non adjustable, only reason why im asking is that my clutch pedal biting point it right at the top. thanks
clutch isn,t adjustable its hydraulic is this on a corolla ? or a vauxhall looking at your car model if its on a cable it could be !!!
