Fuel Filter
Diarmuid
Hi there
I have 2 Toyota corollas. one is a 07 vvti saloon and the other is a 05 vvti estate. Is there a fuel flter in these cars and if so where is it located. Thanks. Diarmuid
If your vehicles are like this one.
Then the fuel filter is in the fuel tank. Supposedly it doesnt need changing.
If it is not the same as the pic above im not sure.
as above, fuel filter for petrols is in the tank and doesn't need changing unless you put wrong fuel in and the filter for the diesel is in the engine bay I change mine every 20K
Thanks for your help
DIARMUID
