Wher Is The Fuse For The Indicator Lights?
ClubMem
Can anyone advise where is the location of the fuse box containing the fuse for the indicator lights on an 03 Avensis D4-D T3X diesel hatchback?
Thank you.
ClubMem
Thank you.
ClubMem
Could be number 39 a 7.5amp located in the instrument panel fuse box behind glove box or number 23 a 10amp in the engine comp just behind the Battery.
Fitter
Thank you.
ClubMem
Hi mate here are some diagrams for you, it should help you locate all the fuses.:thumbsup:
Regards Pete.
