First Question!
Littlewood
nope as far as i know they are just glued on. use some glue/residue remover to get rid of the gunk left behind and then just use some super resin polish or something similar to shine the paintwork.
debadged.jpg they are stuck on with a sticky back foam, i used auto glyms intensive tar and film remover to get rid of the sticky stuff worked a peach.. you should try gently heating the badges up with a hair dryer on mediom heat till you can wiggle the Badge and then pull it of gently or you end up leaving the foam on the car
