Broken
brad
alright car wont start windscreen wipers wont work... niether will the horn.... Battery is fine all the fuses r fine wires look to be fine... can neone help? indicators do work :help:
Turn on your head lights. Are they strong and bright. If yes leave them on for 3 minutes...are they still strong?
Indecator lights take less Battery power to turn on than wiper motors or horn.
If your lights go dim within 3 minutes.....then the Battery is almost dead.
Had a problem similar to this in my last celica. Turned out the altenator had packed in got the old one rewound at a repair shop, worked a treat , hope this helps
after slappin the old man for about 3 hours turnd out he disconnected half my wirin harness from the ecu and that was the reason took me 4 hours of :censor: ing round b4 i figured too look near the ecu
i had a same problem with my car too i just disconnected the battey for a little while then put it back and it works fine now :lol:
