Cts Supercharger
nrgizerbunny
Is it just running the base map?
Really interested in what was involved in making the PFC work, did you just get one of those harnesses you were talking about a few months back and plug it all in?
Did you have to program your keys back onto the PFC?
  • Replies 471
  • Created
  • Last Reply
Top Posters In This Topic
  • nrgizerbunny
    213
  • KPARRIS-JONES
    43
  • CorollaD4D
    34
  • Clawliger
    28
I made my own harness, it's plug and play. no need to reprogram keys because the stock ECU is still in the car.
The apexi has the monkeywrench map in it and I think that is my issue. Going to have a poke with the fueling levels and see where I go, the wideband is going to AFR of 11 when it's starting to splutter so clearly too much fuel.
You could just plug in an apexi into the car and it would work but the following would not function:
1. Power steering
2. Gauges
3. Air Con
So in effect, you've piggybacked a standalone ECU - excellent work
You need to share your secrets!
Not quite, A piggyback modifies the stock ECU's signals.
The install I've done doesn't use the stock ECU for any engine control whatsoever, the Apexi does all of that.
The stock ecu is just there to make the gauges/air con work.
1. Power steering
2. Gauges
3. Air Con
Won't you have constant CEL's?
Dunno yet..
At the moment the Apexi is in control and the Stock ECU knows it isn't.
My next step is to fool the stock ECU into thinking it is still in control. I need to feed it with an IGT signal, VVTI signals and perhaps an O2 signal.
Okay, it's got a bit of compressor surge when its parked up if I rev the !Removed! off it.
I will see what it is like under load.
Exciting stuff mate, make some videos unless you want half of Corolla club turning up at your turn step! :lol:
Oh dear, I got a bit excited whilst driving the car up and down the road that I booted it (on bog standard injectors = detonation), the yellow warning light came on followed by a plume of smoke and it filled the cabin up too. I had to push the car home :(
Awww sh*t, does that mean your going to have to tear the engine down?
Turns out I had blown an intercooler hose off. Put it back on and running again.
SCREW ME ITS FAST!!! SERIOUSLY FAST! thats even without me giving it full wack on OEM injectors.
And thats with a crap tune too!
i sooo badly want to drive this car lol :D
great build mate
just be careful, you dont want to put your hard work to waste
have fun!
on the edge of my seat mate ,excelent work ! now get data logging and tuning! we need to see this :thumbsup:
S c o t t y
a bit of an anti climax but i've disabled the supercharger until next weekend. This is purely because I'm so tempted to nail it and don't want to stuff it up.
safety first!
It seems by the time this project is done u may have exceeded TTE's ability to improve the T Sport...
Well done! :thumbsup:
Haha,
I have tried to make everything very reliable so we'll see how it goes. I carry on where the OEM stopped!
Todays update,
I have installed some gatorback belt onto the drive of the supercharger, it is supposed to be more resistant to slip because the contact pressure is higher. I didn't really have problems with the gates belt but this was on eBay and thought it was worth a punt so I bought it. It is way way easier than a standard belt to install though.
You can see the comparison between the gates and the goodyear here.
It doesn't look like it has the same profile but it does!
Here it is all piped up.
I love your updates mate
"Test drove it today with the charger connected, felt like lift at 1500rpm but that's not important, just look at my new shiney drivebelt" :lol:
