Slight Noise On Engine On Compressor
215 compressor
just wondering if anyone has this similar noise on there tsport or compressor its a slight rattle which sounds like it coming from the variable valve timing gear or the timing chain .just wondered if its characteristic to this engine ,performance is not affected its slightly louder as the engine gets hotter .
Hi
My compressor is also slightly noisy from that area, more so when hot,dont know myself if its normal because only got mine a few months ago. My best guess is that the oil is thinner when hotter so things sound noisier. But i am keeping an eye on it, or ear, in this case.
i get a rattle on my t-sport at low rpm when pulling off but iv heard its a common fault with the exhaust manifold heatshield not sure if its the same thing
its not as you set of its easier to hear when hot and at idle slightly goes of as revs go up
HAving listened to the noise on my compressor again it sounds like the noise is coming from the super charger, going to check the oil ASAP, plenty of people having issues with them running dry and they are pricey to replace. Will let you know if topping it up makes noise go away
I've got exactly the same on mine sounds a lot louder at 4000rpm and it's definatley coming from the top of the engine, is your lift affected?
NOw checked Super charger oil, there was some in there, but not showing on the dipstick! Ordered some from eBay america. Hopefully this will make the noise quieten down.
Lift seems to be fine, cant hear any strange noise at 4000 rpm either, worth getting your s/c oil checked.
Already done that, even changed the oil for fresh and still same. I would understand if I abused it but it gets everything! I wondered if there was an engine specialist for the 2zz-ge engine about?
i don,t think the noise is from the supercharger but the best way to check and eliminate the supercharger is to take the belt of and if the noise is still there then its on the engine .
Mine has a rattle from camshaft area, my waranty runs out this month so guna get some bits replaced i think, need to have the cover off to see what it needs though.
be interested to see what you come up with keep us posted
