Corolla Auto Problems
corollanutz
Hey, I swapped a motor/trans from a 2000 corolla S into a 1999 corolla. After modifying the shift linkage I still can't get "drive" to function. The car will shift if you manually shift from L to 2nd to D. Drive seems to be stuck in 3rd. I noticed the 2000 Corolla S has a Overdrive button on the shifter. The 1999 Corolla is missing a plug on the wiring harness that would plug into a spot next to the shift arm on the transmission. If anyone could help me get drive to function correctly their help would be MOST appreciated. This is my first Toyota. THANKS!
