20V Silvertop Conversion Problem
4A-GE TRD
hi toy peeps i got a 20v conversion in my ae-92 i recently got a piston failure or so i think..my 3rd cylinder..spark plug is wet..changed plugs around either way it still get wet at 3rd, changed all plug leads there is current running through..the other thing is theres oil coming out the 3rd throttle too! And its blowing out air instead of sucking..note.car does not smoke..could it be the oil rings? Help plz
Could you explain the second part cos i dont under stand what you mean.
Wet spark plug could be unburnt fuel you could have a misfire,
sounds like serious piston issues to be fair but to confirm is the plug wet with oil or fuel?
if its fuel it could be a coilpack or lead fault, if its oil its FUBAR
That's nasty! If it's water then I am surprised it's not bent the rods... maybe the gasket has gone?
If there is oil coming out I would expect the rings to have gone, plus if the spark plugs are coated in fuel then your injector id either mistimed or dumping it in there... as Dawesy said, coil packs.
