Corolla 2000 Replacement Key - Help....
st1
Hi All
I am new here and hopr you can help. I just purchased a X plate (2000) 1.6 auto corolla and the only key I was given is the light grey supkey which is fine but cannot be used to remotely lock the doors. I rang Toyota and they say I need to replace all locksand ECU. As I do not have the master key what options do I have? I assume someone can make this key and if so any recommendation's/ And roughly how much will this set me back?
thx
ST
