Drilled And Grooved Brakes
b1gpkr001
Hi all
looking at getting drilled and grooved front disks but i have standard disk on the rear that are newish.
can i run the drilled and grooved disks on the front and keep the rear brakes standard?
all so looking at geting some lowering spring and have found a set of apex springs for £112 any one using or have used apex springs? how have they been?
one last thing if i change the springs is it worth changing the dampers?
Phil
As above for brakes. As for lowering springs you will have no prob's with stock shocks however if you have the funds then it's worth changing both.
