Sign in to follow this
NAM8123
How To Connect Replacement Hu To Factory Subwoofer?
Hi, I've also posted this on the Celica forum.
New owner here! Just got a 2005 Celica VVTI with the premium and style pack, so it has the active sub woofer in the boot. I've just replaced the factory HU, the new Pioneer one connected fine with ISO adapters, but the active sub can't connect as the HU only has phono connectors available on the back. Although the HU sounds fine it would be good to get the sub working.
Has anyone else fitted an aftermarket HU and found a way of connecting to the sub without cutting the wiring loom ie does a phono to wiring block adapter exist? If not and the looms has to be spliced, what is the wire decode for the sub.
Look forward to your help on this one.
:thumbsup:
Share this post
Link to post
man-bing,
Thanks, Caraudio direct are near me in Wallingford so I'll give them a ring!
Share this post
Link to post
I know this post is quite old now, however I have the same issue, did you manage to find a solution to this problem?
Rishi
Share this post
Link to post
This was my solution to the prob, have a look and see if it helps you too
Speaker to RCA (Phono) Converter
Bing
:thumbsup:
Share this post
Link to post
