How To Connect Replacement Hu To Factory Subwoofer?
NAM8123
Hi, I've also posted this on the Celica forum.
New owner here! Just got a 2005 Celica VVTI with the premium and style pack, so it has the active sub woofer in the boot. I've just replaced the factory HU, the new Pioneer one connected fine with ISO adapters, but the active sub can't connect as the HU only has phono connectors available on the back. Although the HU sounds fine it would be good to get the sub working.
Has anyone else fitted an aftermarket HU and found a way of connecting to the sub without cutting the wiring loom ie does a phono to wiring block adapter exist? If not and the looms has to be spliced, what is the wire decode for the sub.
Look forward to your help on this one.
:thumbsup:
  • 3 months later...
