Typhoon Help
adrock11
fairly sure you pull it off and put a cap over it. im sure thats what i did on my 05 tsport. had a T shaped bit of vacuum hose left over.
i would wait confirmation from someone else though
yeah theres a cap in the bag, stick it on the tshape bit after removing the little bit of hose
im sure i removed all 3 hoses joined together by a T shaped plastic bit
Or if your kit didn't come with a bung because you got it off eBay and the seller was a !Removed!, cut the hose back and tie it into a really tight knot! Sorted :P
