Does An 04 Cts Use A Canbus System On Headlights?
thank you nrgizerbunny, you've helped me out twice now!, i got to the fogs from under the car as you suggested, and know i can get these bulbs ordered, top man :thumbsup:
also ive just noticed on your hid fitting guide that you have to drill into the cluster? why is that,? i always thought these were plug and play kits?
the cover which goes on the back of the headlight for bulb access. the car wiring is already inside the light so a normal bulb you plop it in, push the connector on and you're away. a hid bulb has wired coming to it which you need to drill into the back cover and the hid kits have grommets in them for water safety etc you get the picture.
