Power Steering
popadoc
I have the same problem. sticky and makes noise, very hard to turn, have to force it both ways for a while then it works just fine. any thoughts?
hi can any one tell me why my power steering is sticky on start up i have a t3x 2 lt
Probably low on power steering fluid.
Pete.
  • 4 weeks later...
could it be trapped air? the steering fluid level is ok.
Could be air locked but have you checked the drive belt tension or fitted a new belt. It may also be a sticking system pressure relief valve/flow control valve spring or a worn pump but that is unlikely.
Regards .... Pete.
