Starlet Clutch
cheekybum
1985 999cc early FWD Starlet with a slipping clutch.I've found a pattern (IE cheap!)clutch kit on the internet but would apprieciate a 'walk through' guide to swapping it in.I've learnt already that the gearbox will need to come out,and the n/s driveshaft.
Am I best working from above or below?
Am I likely to need a replacement seal for the driveshaft/gearbox join?
Any advice on supporting the engine?
Will I need a puller for the hub?--if so,is it special Toyota tool?
How long should the job take for an average DIY type?
